Lexmark X1270 All-In-One InkJet Printer Logo
Posted on Feb 07, 2008
When l print paper is blank,when l copy its ok
Printing is blank,copying is ok
  • Anonymous Feb 14, 2008
    Scanner is working but printer say there is no comminication with printer
  • croyprym May 08, 2008
    I am having the same problem with my x1240.
ednaedna
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 22, 2011
ednaedna
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
188
Points
I have the same problem. mine is printing but blank. i can see ink coming out from the cartridge..still its blank
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 01, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
792
Points
7
Hey scousemanc
well do one thing make a fresh installation again . go to www.lexmark.com download the drivers.
after installing it , do self test in the printer . if you go to menu options in the printer u will get self test option.
either wise try use different USB port , and make a fresh insatllation, and chekc it
2answers
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
This morning I thought I would print out some Shamrocks (for T.S. windows) on green paper. I put the green 8 1/2 x 11 in the bottom tray and asked the printer to print 5 copies. It would print 1 copy and a...
Was the green paper the type kids use in school. When my kids were little we called it contruction paper. If this is the case, your printer is smart enough to know that this paper is thicker than normal. It's responding as it should. Next time you want to print on this type of paper - select this in your printer's software control panel.
ADF Pulls paper but prints a blank page
The wire ends have different sizes to avoid to connecting it to the wrong port. It will only fit to the right one.
If the copy prints a blank page, try copying again with the document facing up on the ADF.
Hope this helps!
2answers
All copies are blank
What happens when you print a report? Do you get print then? If you can print reports and then you get blank copies the problem is your scanner. If you can't print or copy, then the problem is in either the drum, I would say 30 percent, or laser probably 70 percent.
But we have to find out if it will print a report. Do you use the machine as a fax ? Do they print ok?
Blank paper syndrom
Can you do a simple color or b/w copy job? If yes, the ph is OK and you might have to reinstall the drivers (delete before that the old ones).
If you cant see any copy job (blank paper) you should change to original carts and run the manual cleaning procedure twice. Wait a few hours an try to do the printing again. You might have to run the cleaning procedure twice again!
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
