My automatic espresso machine won't grind the beans - it makes plenty of grinding noise but then stop and turns on the red light indicating there are no coffee beans.
Do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Thanks pierre, that's very helpful.
The problem is that the cofee beans will NOT drop into the grinder, which still works.
I removed the shut into which the ground coffeegoes. It was clogged. I cleaned it. I turned the grinder on and could see ground coffee coming out. BUT, the clogg seems to have back up onto the input side of the grinder preventing the beans from dropping into the grinder.
I see two screw on the back. However, before I attack it with a screw driver, I would like the schematic so I know how to safetly remove the plastic whole coffee bean holder so that I can clean the input side of the grinder and then reattach everything.
Thank you!
Ralph de Juliis
Tulsa, OK
how can we get it to grind more coffee?
After turning off and on machine it still stops at the fill tank command
