Just make sure the right colors are in the right place, photo magenta is not interchangeable regular magenta. Also run the nozzle check to make sure all colors print, if after 2 deep clean cycles you don't have all colors you may need a new printhead.
If your printer is fine, you need to go into printing preferences and adjust the way color prints, Canon has adjustments to change the color and hue and even print in grayscale. One other thing to check is the yellow color cartridge, if it has turned a darker color in the cartridge then the membrane inside the printhead is bad allowing cross contamination of the colors.
yes, I clean the head. My printer is fine.
have you tried to clean the heads?
