Hi RJ0804, it’s quite easy to disassembling your mixer (OK, it may require a little bit of effort). Here are links to three excellent websites that detail with pictures the disassembly, re-greasing and reassembly of a KA Mixer.
This will allow you to remove the top housing of the bottom of the mixer and provide you access to the gears within the head of the mixer.
Once you get that done, you will want to have the Part List manual around for the rest of the disassembly. If you're lacking one, you can download it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150P and select the next to last file KSM150PSWH0.pdf (773.44 KB) (it’s the white model that’s all…) listed under Parts List (61). (Verify that it matches your mixer model, though).
To disassemble your mixer you will need the following tools: a regular & Phillips screwdrivers, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify, replace and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
