Are you trying to uninstall SQL server?
Sometimes uninstalling this program can be tricky.
The best way to uninstall it is through safe mode.
Log into your computer through safe mode and uninstall the program.
If you need steps to log into safe mode, follow these steps:
Start your computer, then press F8.
A list of options will be displayed,
(some of these options will include, start windows normally, safe mod, safe mode with networking)
Select safe mode and wait for Windows to load.
It will ask you for your login, log into your administrator account, the account you use for installing your programs.
When you are in safe mode, go to your control panel and uninstall all the components of SQL server.
Let me know if you need more assistance.
Thank you for using Fixya,
Kenneth
Hello again,
SQL server components always have installation problems and the best way to solve this problem is to refresh your system and reinstall your Office suite again.
This means you will have to reinstall Windows XP.
Installing Windows XP leads to data loss in your system partition, that means you will have to back up all your data before installation.
After installing Windows XP, you should also install service pack 3 to enable a more stable installation of Office suite.
If you dont have a Service Pack 3 installation file, below is a link where you can download and install an official Microsoft copy, from Microsoft's downloads center.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://www.microsoft.com/downloads/detai...
If you need guidelines of reinstalling Windows XP, let me know so i can provide you with the steps, or you can view my tip on Windows XP installation.
If this does not solve your problem, it means that your Office Suite CD2 installation CD is faulty and may need replacement.
If you need any more assistance, please let me know.
Kenneth.
Hello again,
After all the options you have already tried, it seems like the only way to solve the problem is through the system refresh.
Please remember to backup all your data before you perform an OS re-installation.
Thank you,
Kenneth.
Please uninstall the sollowing softwares from control panel.
1. Microsoft SQL Server native client
2. Microsoft SQL Server Setup Support files
3. Microsoft SQL Server VSS writer
4. Then Move the directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use, if you need it later.
5. Then deleted everything under c:\Program Files\Microsoft SQL Server folder and delete the folder itself. If you couldn't delete the folder, reboot your machine in safe mode and try deleting the folder contents.
6. Now reinstall the SQL server again and this time your installation should succeed. All the best
Thanks
All the files under c:\Program Files\Microsoft SQL Server folder will have files pertaining to SQL server and deleting this folder will not create any problem with your operating system. But you have to do this after uninstalling it in control panel. If possible, create a system restore point by clicking start -> programs -> accessories -> system tools -> system restore
Thanks
This
issue occurs because the registration for the SQL Server 2005 SQL-DMO COM
library was deleted. To re-enable SQL Server Enterprise Manager and other
programs that depend on SQL-DMO, register SQL-DMO. To do this, run the
following command at a command prompt:
regsvr32.exe sqldmo.dll
Step 1: Make sure that the Microsoft SQL Server Setup Support Files component is installed
loadTOCNode(3, 'moreinformation');
In Add or Remove Programs, make sure that Microsoft SQL
Server Setup Support Files appears in the list of installed programs.
If Microsoft SQL Server Setup Support Files appears in the
list, go to the "Step 2: Run the command to uninstall the SQL Server
components" section.
Files does not appear in the list, install this component before you
continue. To install this component, follow these steps:
Note In the "Step 5: Uninstall the Microsoft SQL Server Setup Support
Files component" section, you uninstall this component.
Step 2: Run the command to uninstall the SQL Server components
At a command prompt, run the following command:
"%ProgramFiles%\Microsoft SQL Server\90\Setup Bootstrap\ARPWrapper.exe /Remove"Uninstall the SQL Server components one at a time
until all the SQL Server components are uninstalled.
loadTOCNode(4, 'moreinformation');Â
Step 3: Uninstall the support components
Use Add or Remove Programs to uninstall the support components in
the following order:
APPLIES TO
Check out the link below for more information and help...
Source: http://support.microsoft.com/kb/909967
you don't have to move the folder, you could just rename it. right click on the folder and choose rename, or click once on the folder and press F2 to rename it. this will trick the program to be not there when in reality all the files are still there.
Hope this helps!
Yes, you can complete the same process. IF you have ay questions please refer to the link I sent earlier
If you have removed it from control panel, its done. You just have to clean up any left over registry entries using CCleaner and then try installing again
http://www.ccleaner.com/download
You may also want to check out this microsoft link if it doesn;t work
http://office.microsoft.com/en-us/help/HP011128601033.aspx
I have already read that in you profile before hand. Did you try the solution I have suggested? It's already uninstalled, you just need to clean up the leftover registry entries. Then download and install Microsoft SQLserver express edition 2008 advanced(type it exactly as above in google and you will get the direct link). It should have all the stuff you need to install the office suite and business contact manager. I'm posting from my phone right now due to a peer outage, so if you could not figure it out let me know and I will post a much more detailed solution as soon as the power is back.
Sai.
Check to see if there are any SQL services running? How to check? Simple launch the SQL server 2008 setup and it will automatically check and let you know if there are any previous instances of SQL server running. If they are then yes you will have to remove them. Otherwise you can just continue with the 2008 installation and once its done try installing the office suite once again.
Sai.
Boot from the CD and re-install the OS, you will not loose any files as vista will only remove the OS. YOur documents and stuff will be moved to a folder windows.old. So do this and try re-installing Office 2007. This is the quickest and easiest way to get rid of this SQL problem and there is a good chance that this will resolve the issue.
Please accept this solution if it resolves the issue, or let me know if you need more help,
Sai.
Not that what I meant by booting is, insert the CD and reboot the system, and start the installation before windows starts, not from windows.
Sai.
If you are running XP the process is slightly different. Why? Because XP delets all your user accounts and documents. SO make sure you back up all the data in all user accounts including the files on your desktop before you proceed. Once its done follow these steps, as the overwriting OS procedure is a little confusing.
So here's the plan:
1)Once you boot from the CD choose to install XP in the same drives as your previous windows installation, usually C drive.
2)Windows will warn you that there is already another OS on the drive and installing another OS will cause problems bla bla bla. Continue anyways.
3)When it asks you whether you want to format, choose "leave the file system intact. No changes"
4)At one point XP will ask you if you want to delete your existing operating system files . Press L and it will delete all your previous windows installation files and the rest of the procedure is just following on-screen instructions.
Good luck,
Sai.
Did it work?
Sorry we have tried all of our options. As you can see none of them worked. I will keep thinking though.
Sai.
Did you try the live chat(free) with Microsoft tech support? May be they know something we haven't tried yet? Click on the contact a support proffessional through live, e-mail or phone.
http://support.microsoft.com/ph/8753
Hopefully they will resolve the issue.
Sai.
Hello eagle338
This is the problem I am having and I hope you can help me. I sent the following to Fixya
I have installed MS Office pro 2007 with Business contact manager on my computer after uninstalling an older version of office pro 2002. The 2007 office suite installed ok but when I start the install for disk 2 containing business contact manager I am receiving the following error.
(Setup failed to install the required component Microsoft SQL Server 2005 Express (MSSMLBIZ). Business contact Manager for Outlook 2007 cannot continue. See C:\Program File\Microsoft SQL Server\90\Setup Bootstrap\Log\Summary.txt for more detail)
I am running XP with enough memory and hard drive space for the install.
I have tried uninstalling and reinstalling office, running the win cleanup utility downloaded from Microsoft’s support site, down loading the latest version of SQL express with sp3 and attempted to install with no successes, adjusting the MSDTC tab to allow remote clients, remote admin etc… and adding a Domain file to the HKEY registry. All attempts were unsuccessful in fixing the issue.
Can anyone please offer a fix or a work around that will allow me to complete the install? This problem is becoming extremely time consuming and frustrating.
Thank and have a great night.
I receiver a reply from bahatt with the following
Uninstall from control panel the following:
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
I than sent
Hay Bahratt,
I have uninstalled the 3 SQL programs in the control panel a few times with no effect on the issue. I didn't try moving directory C:\Program Files\Microsoft SQL Server\MSSQL to another location and I not sure how to. Could you please send me step by step directions of the whole process and I’ll give it a try.
Thanks a lot for your help this has been a real pain and I have limited time to spend on it.
I hope you can help
thanks
Charles
I uninstalled all the SQL items in the programs list and ran CCleaner, the only thing that I did different was I tried to install from disk 2 of the software suite and received the same error message. Do I need to use the 2008 SQL version instead? And do I need to remove SQL and run CCleaner again before I download the 08 version of SQL?
Thanks for your help
I didn't try moving directory C:\Program Files\Microsoft SQL Server\MSSQL to another location and I not sure how to. Could you please send me step by step directions of the whole process and I?ll give it a try.
Thx
There are about 386 deferent SQL files found after doing a windows search, some are windowssystem32 file. Should I delete all of them or will I damage me system if I delete win32 files?
Thanks
SQL sever 2008 not valade for sys32 error
I'm still having the same problem with the install
I'm running XP can I complete the same prosses?
Hello Erone47
This is my problem
I am still heving the same problem as of 2day do you have any suggestions?
Hello erone47,
The computer I’m having the problem with is a business machine and reinstalling the OS was my last resort. I was hoping to find another solution but it looks like I’m out of options if I want to use this software. I’ll be taking down the system this weekend and reinstalling the OS. If you can think of any other options I would like to hear them, If not I’ll let you know if the issue is fixed after the system refresh.
Thanks for your help.
