Lexmark T630 Laser Printer Logo
Posted on Feb 07, 2008
Lexmark t630 frozen
Al of a sudden the led panel reads:  *64 mb  300Mhz
cannot print, unresponsive to all buttons, unplugged, any ideas? was working fine a minute ago
  • Marcel Corzo Apr 09, 2019
    Hi. I have a T632 printer. I have the same problem. Frozen on normal node (motor not running at all); When I turn it on while pressing the select/ back buttons to enter into service mode, the motor starts running. I even can print a text page, but when I get out of the service mode, the printer is frozen again. Could it be any card (for example the network card)? hard reset didn't worked either.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 11, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
19943
Points
24
I can provideyou with the procedures to default the printer. That may help.
1. start with the printer turned off.
2. Press and holde the GO, Select and the Right Menu Arrow buttons while turning the printer on.
3. Hold the button in until the display show "RestoringFactory Defaults" then let go.
4. The printer should come back to a Ready state.
2helpful
Lexmark T630 printer is printing 4 copies instead of one
Based on your question it sounds as it the setting was changed to print 4 copies instead of one:
To confirm it;s a issue with the machine Follow this outline:
Go into the menus on the machine via the control panel -> go into the finishing menu -> 3rd option down should display "Copies" go into their and change it back to 1.
However if that is set to one the problem resides on the print driver/ settings.
IF this does not resolve the issue please post back to this
1helpful
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
I have a Lexmark T630 with the message control panel disable when I'm traying to change a setting.
with the power off hold down the select and return buttons while holding power up till the printer comes to performing self test wait until the config menu show in the control panel. toggle the right arrow till you get to panel menu hit select use the right arrow to change to enable hit select it should say setting saved and your problem is gone
2helpful
Lexmark t630 could not initialize due to a suspected lightning after a heavy rainfall
let me guess it stops about the 64mb range in the control panel? how did i do? any way change the network card static charges mess with the nvram chips. t3xx series are lexmarks that wont boot if the network card is not recognize. this should solve your problem. surge protector are always a goog idea on electronics have a great one
3answers
Lexmark T630 frozen
Try to unplug the interface cable from the computer and power up the machine. It is likely the RIP card aka the controller card.
There are two types of controllers for this printer, non-network and network. Here are links to where you can purchase them:
Non-network
Network
3answers
Lexmark T630
If you are using the Postscript driver, switch to one of the PCL drivers. Either PCL or PCLXL.
If you are using PCL, switch to a different driver.
If all of the above fail, send me a Print to File so I can debug it.
([email protected])
Don
Lexmark T630 printing jiberish, Arab style. **Crazy**
I would check the printer to make sure the correct code page is selected.
Also in the printer's front panel menuj, there is a setting for "Language". Please make sure that you have the correct languqage selected
T630 cannot print color
just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
http://www.dooyoo.co.uk/laser-printer/lexmark-t630/
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
