Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
You didn't tell us the model number but whatever it is, you should find instructions here:
Skyscan website
Our various 'atomic' clocks have either a menu that lets one select or a simple slide switch with US time zones from which to choose.
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter 2. Remove the batteries from the main clock and keep them out until the clock display disappers. 3. Re-install the batteries in the clock. 4. Wait until the display returns and includes the outside temperature display as well. 5. Set the clock again for current time/date etc. 6. Bingo. You are in business.
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
