Stopped working coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
mate really cant thank you enough f05 code on wie167 tilted machine and emptied it out then laid machine down to get access from underneath removed black pipe using grips and what did i find a chewed up baby sock. put pipe back on stood it back up turned it on and bingo machine fully working as new saving me £250 on a new machine.
gonna try and fix my is70c dryer now as it blowing out cold air
