I can't seem to install my 4GB Micro SD card to my Sansa 4GB e260R mp3 player. I tried "formatting" it using SDFormatter V2.0, but when I try hooking up my mp3 player, with the Micro SD card inside, to my computer it freezes up on. So I then have to remove the Sansa out of the USB cord and restart it only for the same thing to happen every time I try hooking it up again. What am I doing wrong, can anyone help? Thanks in advance.
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
