Master
- Posted on Jan 10, 2010
Re: My Dell D 600 will not charge the battery and a...
If the AC adapter is not recognized by the system, the battery charger circuit is disabled. Things you can check:
- In the barrel of the connection to the computer, the small wire in the center is the sensing wire. If bent or broken, then the adapter will need to be replaced.
- If the pin is not bent or broken, try a different AC adapter (Any D-Series Dell adapter will work) IF that adapter works, replace the AC adapter.
- If a known good/new adapter doesn't resolve, then a motherboard needs replacement.
