Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
Chest freezer, stopped freezing, Ptc relay attached to compressor has overheated to point of partially melting.
  • 401 Answers
Some of the PTC relays just give out for no apparent reason. (the brown ones more than any other) But in your case you can see physical signs of overheating. I would suspect the compressor has seized up, or has a shorted winding.
Posted on Jan 10, 2010
SOURCE:
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
Mar 02, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Fan blowing warm air food not freezeing
the ptc overload/relay on the compressors dead so the compressor cannot start,therefore the unit cannot cool,replace the ptc and it will run again
Aug 03, 2011 | Freezers
My chest style freezer will not cool. This unit operated without issue for several years. We moved to a new house and did not want/need to use the unit for a year or so. When I plug it in I can hear a...
its the ptc overload relay on the side of the compressor body,it aids in starting the compressor by momentarily putting your start and run windings in parallel to overcome" locked rotor current",then drops out start windings after unit has come up to operating speed,it also protects the windings if the compressor cant start,they simply unplug off the compressor and the replacement plugs in the same,replace the capacitor connected to this if applicable as this protects the ptc's overload relay contacts
Mar 22, 2011 | Frigidaire FFN15M5H Chest Freezer
My GE chest freezer stop freezing. the light is on no sounds from the freezer. what could be the problem?
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Jan 17, 2011 | General Electric Chest Freezer FCM7SU
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
My chest freezer recently beginonly freezez a little at the top but it 's just cool like a fridge at the bottom
Hi and welcome to FixYa. I am Kelly. This freezer uses the chassis to dissipate heat so that the freezer can freeze. There is not a condenser fan. So what you have is a basic and usually trouble free freezer. If your freezer is not cold at the bottom of the unit there can be a couple of causes:
1. The compressor is running slow due to the rotor dragging on the compressor stator.
2. The PTC relay contacts on the compressor are getting hot and the compressor is shutting off before the temp control cycles the compressor off. Usually that is how PTC relays fail.. one hot contact and the unit cycles much more rapidly than usual and eventually the compressor stops running completely.
3. The system Freon has leaked out of the system and the unit is running on low pressure. (If this is the case the symptom will only get worse and very soon)
4. There is a very remote possibility of the cold control being damaged from an external bump by someone due to the fact that it is located outside the freezer compartment on the chassis.
Thanks for choosing FixYa. Kelly
Jul 09, 2010 | Magic Chef Chest Freezer MCCF5WBX
Freezer just stopped working
Is this a frost free freezer? If it is, and the compressor and refrigerant is good, the problem probally lies with the defrost timer. What the defrost timer does, at regular intervals, typically every 12 hours, shuts down the compressor and powers up a defrost coil to melt any frost that has built up on the cooling coils inside the freezer. It probally the small square box that you mentioned. Some have a hole where you can turn the cam to the timer and that should switch the power from the defrost coil to the compressor.
Hope this helps.
Jun 27, 2010 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Red light on
you should have have let it sit till the compressor equalize if it was running,you may have ruined the ptc overload relay that protects the compressor,try unplugging it and leave it off for an hour,then retry it,if this doesn't help then replace the ptc overload on the compressor body,they just unplug off the compressor
May 09, 2010 | Whirlpool 7 cu. ft. Chest Freezer EH070FXM
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Kenmore Chest Freezer
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
Apr 20, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
429 people viewed this question
Top GE Freezers Experts
craig nesmith
Level 1 Expert
AJMAL KHAN
Gil Shultz
Are you a GE Freezer Expert? Answer questions, earn points and help others
