I am looking for a free Casio 1170 ATC-1200 watch manual so I can figure out how to change the batteries. It's an older model watch, but can anyone help with this issue?
I'll post in case somebody still needs this. This is the general
procedure to switch the ATC 1200 from meters to feet. You can also
switch the ATC 1200 (1170) from C to F. This is very helpful if you
change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the
watch to come up. This is because of a race condition when the watch
gets power. To fix this, look for the AC mark on the inside of the
watch. Under this marking, in a little space to the left, are two
copper pads. Short this out with a small screw driver to get the watch
to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter
abbr for the day is at the top. Also, if you cycle the mode button, it
is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to
the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Follow this link and download manual:
http://world.casio.com/wat/download/en/manual/
Rate me, plz.
Testimonial: "The expert was most helpful in going to the manual I needed. I would recommend their help to anyone who needs help online. Thank you"
