SOURCE: how to install rear bearing on Frigidaire model
Not sure you are up to the job as everything has to come out from the front door panel all the way to the back of the machine.
If you are up to it there is a ball like a trailer hitch on the back of the drum that rides in a plastic saddle screwed to the back of the machine, both have to be replaced. MAKE SURE MACHINE IS UNPLUGGED
The kit was about 30 dollars last time I did it and comes with everything you will need. Don't try to reuse the three screws that hold the ball onto the rear of the drum or you will find out what aggravation is.
Also don't leave out the little ball bearing, it has a purpose.
Good luck
Quentin
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
