Powermatic 66 10" 3 HP 1 Phase 230V Table Saw w/ 30" Accu-Fence & Rout-R-Lift 1660806K Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a powermatic table saw, 7 years old with a 2 hp baldor motor and when i start it the motor hums but the blade just shakes back and forth. I can turn the blade by hand and rotate the motor fan blades, Ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Apr 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
7455
Points
12
You have a bad capacitor or a fouled starting winding centrifugal switch. The switch contacts can be cleaned and burnished and you can pick up a new cap from e-bay. It is most likely the switch. This requires motor disassembly. If you are not familiar with the process, take it to a motor shop. The switch is in the back end of the motor and is attached to the end cover. Sawdust in the motor, even though it is TEFC, it will get dust in it causes this condition.
K W
Level 3:
Guru:
  • Master 509 Answers
  • Posted on Jan 09, 2010
K W
Master
Level 3:
Guru:
Answers
509
Questions
7
Helped
216111
Points
1369
You may have lost power on one of the wires to the motor. Check the wiring for breaks, if you have a meter make sure there is power to the 2 110 volt wires.
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
1helpful
I am trying to find out how old my powermatic 66 table saw is. serial no is 97661400
On the Powermatic 66's the first two numbers are the year in which it was made, so yours was made in 1997. The second set of two numbers is the model. The last numbers I"m unsure of but its my understanding that they represent the manufactured number, so yours was the 1,400th saw made for that year.
1helpful
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
1helpful
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
4helpful
2answers
I have a Powermatic 66 that trips breaker
Either it has a problem with a blade brake or the motor is siezing. Or the is a wiring problem. With the unit unplugged check and see if you can turn the blade by hand, if not the motor is the problem. If it does you could still have a motor problem by it drawing to much amperage or the is a wiring problem.
2helpful
I'm feeding 8/4 alder through the powermatic strait line saw
Sounds like the power feeder is not holding it secure at the end of the pass. Is the outfeed table running level to the saw table?
Just a wild guess, I'm afraid. I haven't used one myself.
The only time I've seen blades wobble like that was when they were light plates, undersized for heavy duty ripping operations. It's truly frightening to watch them overheat and turn to butter like that. I'd recommend getting a heavier plated saw blade if there's any question about yours.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 26, 2009 • Saws
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
12helpful
2answers
My Powermatic 66 table saw won't start. Tried to turn on my Powermatic 66 table saw this morning. Blade moved one half inch as if trying to start. Tried reset button on motor, still nothing.  I...
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
Top Powermatic Saws Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Marty Warge
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
