Timex 27191 Wristwatch Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Quartz sports watch works, loses time, had three months, .
The watch works fine,but loses several hours during the day. I noticed this after about four weeks. It is an NFL Watch gift from Avon.
Anonymous
Level 2:
Scholar:
  • Expert 98 Answers
  • Posted on Jan 09, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
98
Questions
0
Helped
82111
Points
216
Sounds like battery is failing. Time to replace it! :-) Sears stores usually have a watch repair counter...or find a reputable watch repair business. (Even if the watch is new...its still possible the battery could be failing because you have no way of knowing when it was originally installed! They typically last about 2-3 years depending on age and condition of watch!)
Setting the day on an Orvis Quartz chronograph watch
Check out the videos and articles. With my Seiko, you pull the crown to the first position and pushing the side buttons closest to the dial, advances with each press.
https://www.google.com/search?q=Setting+the+day+on+an+Orvis+Quartz+chronograph
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
1helpful
How to set new date of month on watch
How to change date on a watch?
Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. * If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock. 5. Adjust the time by turning the crown in the desired direction.
Instructions for Analogue Quartz and Mechanical Watches - Seiko
https://www.seikowatches.com/support/ib/pdf/Analogue_E.pdf Search for: How to change date on a watch?
How to set new date of month on watch Google Search
Dec 21, 2016 • Watches
1helpful
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
42helpful
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
9helpful
2answers
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 • Watches
Breitling watch move fast
No matter what is your watch movement (quartz or mechanical) it can be adjusted to keep time properly.
Bring it to your nearest watchmaker and the problem will be solved.
9 sec a day is far too much for Breitling.
146helpful
10answers
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
