I just got this phone today and i put the cord in the back then in the jack..... and when i pick up a phone some where elts in the house the Innovage (1604007) starts beeping like (Beep Beep Beep Beep fast) but if i pick up the phone or hit speaer on the Innovage (1604007) the beeping stops.... So the only way i can call out if I use the Innovage (1604007)..... but if i hang up on the Innovage (1604007) the beeping starts again???
If you can help that would be great.
Go to the ipp on your phone and turn that off. then your other phones should work to and so will the lcd.
Here is the fix for that problem...
1st click the set button on the bottom left of the keypad. Press the "up" button (located to the right of the the keypad) until you get to option number 7 IPP. Click the set button again (so you can change the settings for that option) and press the down button to turn off the option. Click the set button one more time and finally press the delete button to get out of your settings mode. No More beep, beep, beep......
Hope This Helped--WICC-
