Hi I have a pair of PW-12H dual 2 ohm power auoustik and I lost the simplified ohm configuation sheet they came with I woud like to know were to get it
A speaker with dual 4 ohm can be wired in parallel (+ to + and - to -) to react like a 2 ohm impedance. Connect both speakers together in parallel (+ to + and - to -) for the 1 ohm impedance. I personally would not prefer nor recommand using a 1 ohm load on any amplifies.
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
To drop the ohms you wire in parallel. If your sub has dual 4 ohm coils you would connect both positives from the coils together as well as join the negatives together- this will give you 1 set of positive and negative wires-this + and - is now a 2 ohm load do the same to your other sub and you have a pair of 2 ohm subs. Wire the positives together from both subs as well as the negatives again and you now have a 1 ohm load. If you have dual 2 ohm coils you can get as low as 1/2 ohm of resistance.As far as i know the jl 500 puts the same amount of power into 1.5 through 4 ohms as long as you stay in that range your amp will be fine
The ohms rating measures the electrical resistance of the subs(impedance). On the subs there is usually a label that tells you what the impedance is for that particular sub,example= 4 ohms . The only way you can get to a 1 ohm load or less with a pair of tens is if each sub has dual voice coils that are 4 ohms each wired in parallel. Generally Sony xplod's are a single coil 4 ohm woofer-yours might be the exception in this case .To figure out your resistance say with 2 subs that are 4 ohms you have to know how you intend to wire them for instance if your amp puts out a fair amount of power @2 ohms and thats the number you want to hit than you will want to wire the subs in parallel( + to + and - to -) wiring in parallel lowers the resistance.(ohms) If you want to hit 1 ohm and you have dual 4 ohm coils then wire all 4 coils in parallel and that will then be a 1 ohm load. Its simply a matter of dividing the ohms by the number of speakers that you intend to connect. if you had 3 10s that were 4 ohms each and you wired them in parallel the ohms would be 1.33 (as 4 divided by 3 is 1.33)(4 divided by 2 is 2) (4 divided by 4 is 1) On the flip side wiring in series will raise your impedance-a pair of 4 ohm subs wired in series gives you an 8 ohm load 3 subs gives you 12 ohms and so on. I wouldnt worry about the high current switch unless youre planning on taking it down below 1 ohm which it sounds like you arent currently set up for.
depends on the impedance of the coils on your subs and if they are single coils or dual coils. If you are trying to achieve a 2 ohm load then a pair of 4 ohm coils in parallel will do the job.If you have dual 4 ohm coils on your subs then you will have to use only one coil from each sub which will still give you the 2 ohm load that you seek but it will affect the power handling of the subs by half as you are only using half of the coils.
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
most car-audio subs are rated at 4 ohms, as opposed to home audio's 6-8 ohms. If you have a pair of 4 ohm subs, wire all 4 positive terminals to the positive terminal on the amp and the sam with the negative sides. The key is to use the same length of wire on all connections.
