The chain on my concept 2 row machine seems to be rusting and may need to be replaced. Is there a way to repair this chain, or would I need to replace it? Is the gear that the chain wraps around accessable to lubricate?
There are lots of rowing machine in the local market.there is best 10
1.Concept 2 model D
2.Concept 2 indoor rowing machine
3.Water club
4.STAMINA AVARI PROGRAMMABLE MAGNETIC EXERCISE ROWER
5.STAMINA INMOTION ROWER
Click the link for more 5 Best Rowing Machines Compared Get The Best Rowing Machine
Most rowing machines can be stored vertically to take up less floorspace. This is also where the caster wheels can come in handy to help you move the rower to a corner, nook or cupboard, and the folding nature of some rowers like the Concept 2 can be helpful for storage in a small space.
Have you checked to make sure there is no corrosion or dirt on the battery terminals/contacts resulting in reduced voltage flow? If dirty try using a dollar bill(the fibrous paper used to make money is slightly course) to clean them as even a fine grit sand paper is too course for these contact points( you just want clean them, not scratch the finish off)
Check the mtion sensing magnetic switch thats under the seat rail. It determines if you are rowing and sends a signal to the computer. Make sure all connections are fully seated. You may have loosened a wire when you swapped the batteries.
You didn't say what model you have, but I believe they are all functionally similar to my Model B rower. There is a "skewer" assembly inside the seat rail with a shock cord and pulley's that keeps tension in the chain throughout its range of travel. To some extent it is adjustable by taking slack out of the shock cord. On mine, this can be done by grabbing the shock cord adjustment mechanism ("SCAM") with pliers and pulling it out of the rear of the machine and adjusting the slack. If it is very loose or you just want to be sure of what is going on, the entire skewer assembly pulls out from the front (flywheel side) of the seat rail after removing four screws that hold it in place. Go to the concept2 website for diagrams, instructions, and parts lists for your model.
