Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vista hp laptop will not print emails on my hp 6300 printer
Joel Rodriguez
Level 2:
Sergeant:
  • HP Expert 465 Answers
  • Posted on Jan 09, 2010
Joel Rodriguez
HP Expert
Level 2:
Sergeant:
Answers
465
Questions
Helped
131020
Points
831
My HP 6300 printer is off line, How do I put in on line
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
1helpful
2answers
Printer does not give test page print
Check the right corner of the cover,you will see a pointing plastic touching the sensor,check if its broken then replace it,if you cant,then you need to replace the whole cover,,,
1helpful
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
My HP 6300 says offline and will not print
same problem no solutio !
delete and re-install printer is the only thing that works and only temporarily ... frustrating !!!
1helpful
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
[email protected] (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
Email prints in garbled code
try downloading HP Smart web printing from Hp.com web site, that should fix your email problems, reply back if the issue is not resolved.
PSC1510 & Vista problem
The problem cannot BE solved. It's yet ANOTHER Vista screw-up.
Original Problem:
"No matter what I try - every page from Jarte prints out with an UNWANTED gray
background.
This does not always happen when I print from the web, make copies or print from
Microsoft Word. I ran diagnostics on my printer HP PSC1510 and it's fine.
Test pages print ok, too.
Please help - I had Jarte on my last laptop (Windows XP), it worked very well
and I liked it much better than MS Word."
I emailed Jarte Tech support and got the following answer:
"The problem you encountered is a bug in Windows Vista. You will see the same problem when using WordPad on Windows Vista. As you have noticed, not all programs are affected by the bug. The problem is occurring because you are using a Windows color scheme that uses a gray background color for text windows. Unfortunately, the only work around is to specify white as the background color to use for text windows. Hopefully, Microsoft will correct the problem in a future Windows Vista service pack."
Bob Flora
Carolina Road Software
k24674
Grand Canyon Tech
Grand Canyon Tech
