Http://www.unlock-free.com/nokia-master/
Takes care of most nokia phones. It's a free solution.Please follow site instructions.
Please rate the solution.
Cheers
Follow the instructions given below for unlocking your mobile from this site http://www.mobileunlockguide.com/ at free cost ..
Warning: Do not enter any wrong unlock unlock codes on
your Nokia 6300 mobile phones. If you enter over a certain amount of
wrong unlock codes on your mobile phone, your phone may get hard locked
and sometimes become unusable.
1 - Switch on your Nokia
6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off"
and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or
Rogers in Canada follow these instructions :
1 - Switch on your Nokia 6300 without any sim card.
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times
quickly
The letter w appears if you press the button star(*) four times
quickly
The symbol + appears if you press the button star(*) two times
quickly
The CODE you need to enter is the unique unlock code for your
Nokia 6300
Each Nokia 6300 mobile phone has an unique unlock code. You
can buy the unique unlock code for your Nokia 6300 mobile phone at www.mobileunlocksolutions.com.
Then get the unlock code for unlocking your mobile in this site http://www.mobileunlocksolutions.com/unlock-your-phone/rs1wp2/ at cheap cost ..
SOURCE: unlock nokia 6300
NOKIA UNLOCK & OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software
Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI
number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to
obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this
power saving feature "SIM Clock Stop Allowed", it means you will get
the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date,
4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To
exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
SOURCE: unlock nokia 6300 sim
This code can't be calculated from IMEI. You need to go to a Service Center.
SOURCE: Need to unlock Nokia 6300 IMEI no. 359835017591948
Step by Step guide to enter the unlock code for a cell phone
: a. Push # b. Push * 3 times in a second. (p will show) c. Push * 4 times in a second.(w will show) d. Push * 2 times in a second(+ will show) e. Enter the code from below. f. Push * 2 times in a second.(+ will show) g. Enter the code number h.Push # Visual Guide on How to enter the Unlock codes for a cell phone
copy from http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
thank you for using fixya.com
SOURCE: Nokia 6300 Unlock Code
If Your Nokia Phone Asking Security Codes So You Can Go To Nokia Care Nokia Authorise Service senter and show there
SOURCE: unlock code nokia 6300
To unlock your cellular you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number.
I can recommend this one (cheap and reliable).
Click here to unlock your Nokia 6300
Note: don't share your IMEI number on forums like this.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
The Nokia 6300 is very simple to unlock. By using our unlocking method, your Nokia 6300 can be unrestricted as quickly as entering a short code into your phone You will achieve a the ability to use the SIM card of your choice. Unlocking your Nokia 6300 enables you to use the SIM card of your choice which permits you to take advantage of using whatever network that is the most favorable for rates. As with all services of Unlocking.com we guarantee 100% that your Nokia 6300 will be unlocked. We have a money back guarantee if we don't successfully unlock your cell phone. We also promise your cell phone cannot be damaged during the unlocking process.
When traveling out of country, your handset will be able to accommodate SIM cards bought locally making it possible to use local networks. An unlocked Nokia 6300 will be a more desirable item for resale. It's simple to unlock a Nokia 6300 phone using an unlock code purchased from us.
