You can eject your cd drive by inserting a needle (saftey pin, sewing, etc.) into the pin hole
near the eject button.
You can also try opening my computer and right clicking the cd drive and select eject.
Testimonial: "master, you are the teacher, I am the student....you are my new idol...THANK YOU!!!!!! "
If media player is frozen press ctrl,alt.del (or type taskmgr.exe in Run box from the start menu) this will open task manager, in task manager under Applications select Media Player and then click End Task. This will end it let me know if it corrected the problem.
Ok do it again and this time go to the Process tab find image name wmplayer.exe (it will show up here) then click end process.
Let me know if it worked.
That is very odd. Have you rebooted your computer? If not do so.
Sorry I was gone all day do you still have the problem? If so restore your computer to a date when you know yoour system worked correctly.
To do this follow the steps below
1. Click Start go to All Programs
2. Scroll up to All Accessories
3. Scroll sown to System Tools and select System Restore
4. Choose Restore My Computer To A n Earlier Date (you can always come back and select undo my last restore)
5. Choose date for restore to complete
If this fixes your computer your all set if not this eliminates the it being a software issue and confirms your problem is harrdware related. Since your software has since gone back in time.
studio 1737. I got the cd out by going to my computer, but the icon light for media player is still on and won't go off, none of the other buttons will light up as a result
1737 got the cd out by going to My computer, but the icon for the media player is still stuck and as a result none of the other plyer options will light up when touched.
I tried the control-alt-delete suggestion, but media player does not show up as being active.
there is no wmplayer.exe on this list
rebooted x2, no change
all in "w" items are as follows under PROCESSES tab:
WebcamDell2.exe
winit.exe
winlogon.exe
WMIADAP.exe
WMIpRVse.exe(one for system, one for network, one for local)
WebcamDell2.exe
winit.exe
winlogon.exe
WMIADAP.exe
can you please confirm which studio model you are using
