I AM GETTING VERY LITTLE SOUND FROM THE SYSTEM
When did this start? What happened just prior to that?
Turn the volume DOWN for any further analysis. If it isn't loud enough to hear well at 1/4 volume, cranking it to the stops will not resolve it AND when you finally find the misplaced switch you may launch all of your speaker drivers right out of their cabinets.
Do you mean the MUTE button does not CHANGE the volume? It sounds like you're muted already and it doesn't UNmute. Is MUTING lit on the display?
Does it happen with all sources? Use onboard FM to troubleshoot as it can't be connected wrong.
my mute button jumps on and off at will and when i try to turn the volume sometimes when i try to change the song on the...
