by "focus priority shutter release" I mean the ability to instruct NOT to allow shutter release (ie FULL depression of the shutter button" UNTIL focus is achieved and confirmed. I have this feature on all my NIKON and OLY pro and prosumer level cameras as well as my Panasonic GH1 (just got this little beauty and love it). I'm asking the question on behalf of a friend who just got the LEICA V-LUX 1.
Thanks in advance ........... jeffm419
The following is quoted from the User Manual for my new PANA GH1
"FOCUS PRIORITY] It will set so no picture can be taken when it is out of focus. [OFF]: This gives priority to the best time to take a picture so you can take a picture when the shutter button is pressed fully. [ON]: You cannot take a picture until the subject is brought into focus."
jeffm419
jeffm419
You can't post conmments that contain an email address.
Ok, got confused. I thought it was focus priority and shutter priority seperately. Reg your question, no. Entry level cameras usually do not have advanced features like that.Ok, got confused. I thought it was focus priority and shutter priority seperately. Reg your question, no. Entry level cameras usually do not have advanced features like that.
A 500 mm mirror lens is a fully manual lens (manual focus no aperture change) using a T mount adapter to your specific camera. The T mount costs some $15. It depends on your camera how to turn off the auto focus and go to aperture priority mode. The aperture on a mirror lens is set, usually at F8, so the shutter is the only item that can be adjusted to get a correct exposure. A digital camera (set in adjustable ASA setting) can change it's ASA to help with getting a correct exposure. Manual for digital camera are usually on the companies' web site.
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus.
AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Press Menu, select the Custom Menu Setting (looks like a pencil).
Select "AUTOFOCUS" and move to right.
a1 AF-C Mode Priority. Set to "Focus"
a2 AF-S Mode Priority. Default is "Focus", change this to "Release". This will enable the camera to fire anytime you press the shutter, regardless of if it's in focus or not. Use this setting if your having problems locking up, especially using some different lenses.
If the AF is set to release then the camera will release the shutter before focus is attained. Set it to focus only and see if it improves. Don't leave it like that, you will miss pictures. Shoot some pictures with the center AF point only in single release and see if the focus is consistently landing in front of or behind what you wanted in focus. A penny on the sidewalk shot at a 45 degree angle in aperture priority with the lowest A number possible is a good quick one. For super fine tuning with a f2.8 or faster use a fuzzy plant branch like a tomato plant. If whats in focus is always in front of or behind what you focused on then you need too adjust the focus(back focus) in AF fine tune until it lands where it should. It's an annoying process that involves shooting, adjusting, shoot again, see if its better or worse, adjust, shoot and repeat. On zoom lenses use the middle on the zoom range because it will usually go from back to front focusing on the long and short end. The camera remembers each lens and the process must be repeated for each lens. Last thing I can think of is the one that no one wants to hear and is most likely the problem, Camera Handling. People have a tendency to get sloppy after getting use to a camera. I have noticed that the VR lenses don't like people that stab the shutter button. It wants to remove fine vibration and a harsh stab makes it jump back to center and if the shutter opens at the same time it will put fine motion blur in the picture and looks out of focus.
I'll give you a couple: 1. Is your mode in shutter priority or focus priority? Check your menus and go into the AF area to see which one it is. If it's in focus priority you will have to be focused on a subject before the shutter releases. The other setting is 'release priority' which will enable you to snap the shutter regardless if you're focused or not. If you tried to re-compose the picture you were trying to take, you may have locked in focus and then when you re-composed it was not in the same area thus not releasing the shutter.
2. 2 button re-set.
After the focus is confirmed, the Shutter-release time lag for the DiMAGE E201 is approximately 0.4 second. If the shutter-release button is depressed in a quick motion without making any pause to confirm focus, approximately 1.9 second is necessary.
It has Multi AF, Center AF or fixed focus. The V1 i had went to 800ISO, if you turn the ISO up a little more may you can set a faster shutter speed. I think the only priority settings are the "scene modes" there may be an action ssetting in the scene modes.
Try the PROGRAM MODE-SPORTS setting. this will keep the shutter speed reletively high unless there is little light. Or use APERTURE PRIORITY MODE with an f2.0 to f2.8 to keep shutter speed high. If pictures were blurry when it went to AUTO then the light had to be low for the camera to select a low shutter speed. If using flash use forced or auto flash not slow sync. Also set ISO to 400 which is >>>. If inside use a larger external flash as the one on-camera is only good for about 10ft. if more than 10ft. away set focus to manual infinity so you don't have to wait for the camera to focus. Hope this helps.
"FOCUS PRIORITY]
pressed fully.
into focus."
jeffm419
