Tv willnotcomwe on.Redlight goes completely out when we try to turn on and then I have to unplug the coed and put it back in to get the red light and when we touch it to turn on it goes green and then back out again as though there is no power.
plug your vcr back in, or undo co-ax cable from vcr and put antena wire to antena in on converter box and wire going to the back of tv to tv out on convrter box
Any malfunction associated with a blinking redlight usually indicates a
circuit problem or defective component. Unfortunately, the days of
taking off the back cover of your TV and replacing a defective tube or
fuse are long gone. Proper servicing will require troubleshooting
procedures that can only be performed by a qualified electronic repair
facility or professional television repair person. Ask for an estimate
and a realistic appraisal of whether the set can be adequately fixed.
Depending on the age and condition of your TV it may not be cost
effective to repair.
I have just fixed my own LG 26lc55 flatscreen.. with the problem of the red light is on and when i turned on the tv, nothing happened not even back to the redlight.. Solution-- take off the back panel, in the middle there is a brown " plate " with a lot of electronics, one of the black capacitor is burned out. if you look closely at the top you will see one of them is broken " the + on top is open " in my case " maybe all ", it was a 3300 uf, 105 degree, 10 volt capacitor, i took it of bought a newe one at a electronic store " 3 $ " and put it in. took 10 minutes and my tv is now working.. BY THE WAY, i could not find the exact capacitor, so i bought a 3300uf, 105 degree, but 16 volt. and it works like a charm.. REALLY HOPES THIS WILL HELP YOU..!!
Good Day, msteaz;
Not sure what the light is doing but try to reset the TV by unplugging from the A/C outlet for 5 to 10 minutes. If no fix come back with Model & brand.
Good Luck, big Irish.
