What do I need to record/play loops&samples w/microKorg on stage?
Hey! I've just happily purchased a microKorg and want to get the most out of it on stage; however, I'n new to the synthesizer/MIDI world.
All I want to do is, during a performance, be able to play a melody on the keyboard (or have one programed to a button on some sort of module and play it on demand when pushed) and record it simultaneously, and have it play back in a loop while I play a new, separate melody on the microKorg. I'm also looking to do the same thing but with audio samples and such.
I know I'm going to need a MIDI interface for my computer, but I was looking at the korg nanoKontrol or nanoPad to accomplish these tasks- by their description, they seem like they would accomplish this- but since they're expensive I want to be sure. I'm just not sure what to do or what kind of equipment or hookup I'd need to accomplish this.
Re: What do I need to record/play loops&samples...
I'd recommend a looping pedal as the simplest solution. Check out this link:http://www.recordingreview.com/articles/blogs/67/Confusion-With-Loop-Pedals.html Consider joining. It's free and there is a wealth of good info on gear, Midi, recording etc. Let me know if this helps.
If your Roland BOSS RC-20XL Loop Station will not record or play, there are a few troubleshooting steps you can try:
Check the power source: Make sure that the Loop Station is properly powered and that the batteries or power supply are providing sufficient power. If using batteries, try replacing them with fresh ones.
Check the connections: Ensure that the input and output connections are properly connected and that there are no loose cables. Try using different cables to see if that resolves the issue.
Check the settings: Make sure that the Loop Station is set to the correct mode and that the input level is set appropriately. Refer to the user manual for guidance.
Reset the device: Try resetting the Loop Station to its factory settings. Refer to the user manual for instructions on how to do this.
Service: If none of the above steps work, the Loop Station may need to be serviced. Contact the manufacturer or a certified repair center for assistance.
Hopefully one of these steps will help you get your Roland BOSS RC-20XL Loop Station working again.
Look into all the settings, some of these has a setting to turn internal speaker jacks on and off. I have a casio that can turn them off when playing into the computer.
NEVER CONNECT PEDALS THROUGH THE EFFECT LOOP OF AN AMP. They are NOT design to work at the same signal levels !!! ONLY use effect units that are design to be used in amp effects in the amp effects loop/
your parallel loop only has input, a series has out and in, you need to patch the out of amp to the in of the pedal, and out of the pedal to the in of the amp fx loop. then you need to make sure your loop is turned on, via switch or footpedal.
Make sure you start and terminate the sampling on the beat... otherwise when looped the thing can't "splice" the sample without clipping the sample to tie the start and finish together... and keep the rhythm.
You might want to review your manual regarding modes they may have that are more tolerant of the splicing of the sample.
The unit needs to be repaired. Since it is a thermal problem, you can likely find the bad part with circuit cooler. See if the volume control affects the loudness of the howl... If it does, probably an op-amp in the preamp before the volume control is sick. If it doesn't affect it, then the output amps are suspect. Also check the power adapter.
You sound like you have a good grasp of what you would like to do. There are lots of videos on Youtube of people using some of the gear you mentioned. Also check each manufacturers site for forums on the gear you would like to use. The forums usually consist of members who are all friendly and have good advice and solutions for any problems you may have. Remember that even the most experienced musicians started somewhere and are all still learning and are very willing to share what they know. You might consider using a laptop with an external hard drive. I think the Akai gear is very good and has good support and expandibility. Decide first what main pieces of equipment you would like and contact as many dealers as possible to get the best price. You may be pleasantly surprised and have enough of your budget left over for something you hadn't thought of yet. Good luck and enjoy your playing. Remember to study all your manuals carefully.
I can tell you what it is from first-hand experience. The audio in LED's coming on and going out means that a power supply putting out more than 9 volts DC was used...or the wrong polarity. Korg sells a repair manual for about $12 but they ultimately need a whole new circuit board. If the wrong polarity supply was used, then maybe only a diode was damaged. This would be a cheap fix. But more than likely it knocked out one of the large surface mount IC's that us techs don't even dare to replace. Korg charges around $280 for a new circuit board. A used working microKorg sells for this much.
Honestly, I would stay away from Korg products and many others. Many companies are now using surface mount components which are cheaper and harder to fix. Moog synths are expensive but they are completely fixable(and are built to last). If Korg would install a $0.25 voltage regulator on the input of the DC jacks, the unit would be saved. I think this pretty much sums up the build quality. This is probably not what you wanted to hear but is how it is unfortunately.
A diode or two could need replaced. I can't find a schematic. A microkorg would not be a fun project to take on yourself. Check this page and put your zip code in and check for a repair center (if you are in the US..I don't know if there is a repair center in Japan.
