Please use the following steps: 1. Remove the router and connect it directly from the pc to the modem. 2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first. 3. Check you internet connection to see if it working. 4. If it working, connect the router back up. If it not working contact your ISP for dsl support. 5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address. 6. Check you internet connection after the release/renew
1.Log into router 2. Verify wireless router name( on the computer) >>> ( on/off) 3.Note router name you are connecting to. 4.. Check the laptop do ipconfig /all to see current IP addresses. 5. Set the laptop up in the router by WEP KEY or MAC address. 6.Note router name you are connecting to. 7. Move the laptop about 20ft away and try to log on to the internet. This is for all routers to set up wirelessly.
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection
through control panel > network connections.... if you get the ip
adress in the range of dlink router then try going to start > run
> type "cmd" and hit enter >command prompt will appear... in
command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings and change MTU settings then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Are you able to get into the router configuration somehow? You need to open ports on the router, for the xbox to not be moderate. Let me know the model router you have. If you like I could connect in to your computer remotely and give you a hand with it.
i assume that you're not prompted with the log in screen. if so, you need to check if your computer is properly connected to the LAN/ethernet port of the router (Note: you need to use a hardwired computer if you want a stable connection while checking your wireless settings) and if it has a valid ip address which shoud be within the subnet of the router's ip address (Note: by default the router's ip address is 192.168.1.1 and "admin" is the default username and password)
if you're not sure of the current ip address of the router. go to command prompt and type ipconfig. it'll list there the default gateway which is the router's ip address.
now if you have checked that the computer has a valid ip address and it is properly connected to the router but you can't still access the router's page, there could be a program that is blocking the connection. try to disable any firewall or any antivirus programs installed on your computer.
hope this'll help you. you can click here for the manual if you would like to read some more about the router.
it only hands out private ip addresses. they typically start with 192.168.x.x.
in the setup of router make sure and change all default values for Administration (router username/password) and also change the default IP Address of router to whatever you like, e.g router ip can be 192.168.1 - 249.1
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
