Your problem can usually be traced to the tank check valve. The valve lets air into the tank then closes when the pump shuts down and the pressure regulator bleeds off the head pressure so the motor can restart when the pressure drops to where the regulator tries to turn the motor back on. If the tank check valve is stuck open the motor has to fight the tank pressure to restart the air pump. If it can't turn over, it will blow the breaker on the motor or the breaker for the outlet you are using. The copper line from the air pump is attached to the tank check valve which is screwed into the side of the tank. Some can be cleaned to work again but most have to be replaced. You'll need C-H part number CV221503AJ or similar check valve.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
