Hi, I just bought Companion 3 II speaker a month ago and I sometimes notice that the left speaker is sometimes soft or no sound at all. It does not happen always, it is plug to my PC most of the time but I tried to attach to a different source once {PSP} and it happens again.. Is this a speaker problem ? Any advise? Thnks,
I bought a set of Bose companion 3 speakers and the darn RCA jacks are cheap and wiggling loose. The cost to send back and repair out of warranty is about $125!! BOSE companion speakers may sound good, but for my money, I'd rather go with more reliable computer speaker systems like Creative or Logitech. BOSE IS WAY TO OVER-RATED, but HEY....they suckered ME out of $275!!!
Dear mr.jtolentino,
there seems to be a problem with your speakers.. have you checked the balance of your speakers in the volume control menu option? if yes and still you are getting the same problem, then there is a problem with the speakers.. to test this out, please connect another set of speakers to your pc or a headphone to your pc and check it out. if the new set of speakers are working, you must need to repair your old set.
Thank you sir.
Thanks Brainbox. I actually did check the balance in volume control during that time when its giving problem. connecting another headphone or speaker is not reliable as the problem comes intermitently. Am trying to figure out how to demo the problem when i go to the service center...:)
I have the same problem, but mine is for the right audio jack..the speakers work fine and I have no clue where to repair this system
Moved from the USA to Asia and my wife put 220V into my companion 3 and shorted out the fuse I found the fuse and replaced it with one of the same volts and got the system to work with base and left side speaker working fine but the right side seems to have lost its high range output and has a faint low range working.
what do i need to replace or are parts even available to buy and can anyone idenify what i need to replace?
In would have to go to Singapore to find the parts!
