Question about Xerox 212 Laser Printer
Error code U9
My copier makes one copy and then the error code U9 comes up? which will not go away until I switch it off and back on again. If you have any ideas I would be very grateful.
cheers Mandy
    President:
  • 2,072 Answers
That code normally means you need to do some cleaning to the machine. The majority of the time it is caused by High Voltage arching.
1. Open the right hand door. About mid way down you will see an opening with a very fine wire in it. just a little thicker than a hair. Take a Q-tip with some alcohol and clean that wire. Also gently brush that area BEFORE cleaning with a q-tip to remove as much ink frmo the channel as you can.
2. Towards the top of that door, there is a metal strip, looks like a saw blade, has triangular points on it. I would assume it is pretty black now and not silver. Take a brush and clean that. then gently take a cloth dampened with alcohol and wipe it , very gently until you get it reasonibly clean.
3 Remove the drum cartridge and look for all the contact points. Mostly the ones on the lower right side. Clean all the ink ( toner) from that contact area and look around for all the other contacts to that cartridge.
I would say there is a 90 percent likelyhood this is your problem.
Low line voltage and line spikes can cause this problem, But far less likely.
Posted on Feb 07, 2008
    Genius:
  • 1,601 Answers
U9 High Voltage Power Supply (HVPS) problemThe power supply is failing..
SOURCE:
Error code E541
Ricoh Copier Error Code SC 541 is Fusing thermistor open problem
1. This is Open Thermistor problem
2. Thermistor connector is bad.
3. Thermistor is broken, or out of place
4. Fusing temperature -15% less than the regular input voltage
Might be a one time failure you can reset. Access service mode and reset the code then power copier off & on again. If problem goes away your good. If not.....time to replace the fuser.
Jul 27, 2012 | Ricoh Office Equipment & Supplies
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
Xerox u9-5 code on a 5028 copier
Hello sir; There is a reset procedure require;
hold down 0 while you turn on the power, then enter 20 press start enter 3 press start. turn power off and on.
Aug 19, 2009 | Xerox Office Equipment & Supplies
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
Nov 04, 2008 | Office Equipment & Supplies
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Error code U9
hi im jules_09,are you sure its an error code?chek first all sensor on front door and other parts of the copier that has a sensor,
Nov 02, 2007 | Office Equipment & Supplies
Xerox 212 Laser Printer Logo
228 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
