Place your document or picture on the glass. If scanning film, placethe 35 mm negative or slide in the special adapter provided by HP.Select the Scan Picture, Document or Film button depending on what youare scanning. Select the Make Copies button to copy the document orpicture directly. Click "Scan" and then "OK" to see the scan preview.
SOURCE: scanning a photo
Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
SOURCE: hp deskjet f340 all-in-one-copier and a new computer no cd
Hi. Just go to this link and choose your operating system. After that download your driver for that deskjet printer. I love you.
SOURCE: my hp all-in-one wont scan
First unplug the scanner and install the printer drivers from the hp website. If you all ready have the drivers installed reinstall them. Then go to the printers scan software and try it. If that fail go to start bar-control panel- cameras and scanners and set the printer up. If all else fails call hp directly and they will fix the problem.
SOURCE: HP Deskjet F340 Printing, but not scanning. I have a MAC.
go to your mac hard drive on your desktop go to applications if you installed the drivers correctly you should have a hp folder if not I suggest installing the drivers for your os check your os version by clicking on the apple icon top left and go to about this mac, In the hp folder you looking for scan pro and you can use that for scanning
SOURCE: hp deskjet f340 all in one printer offline
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Deskjet+F340+All-in-One+Printer&opname=HP+Deskjet+F340+All-in-One+Printer&qry=printer+offline+&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=1128309&search=0&submit.x=10&submit.y=8
HP's page for help with Off Line.
