Philips PPF-531 Plain Paper Thermal transfer Fax Logo
Posted on Jan 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i dial on fax number on the fax it is saying no loop current .... has this somthing to do with the settings ????
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Jan 08, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006210
Points
9738
No, loop current is another term for the dial-tone. Your machine is not finding the dial tone.
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
1helpful
2answers
No loop current
One side of the phone line to the unit is bad. This could either be in your cords, internal facility wiring, OR with your Telco.
You should see about 50 volts between the two wires to the FAX.
Plug is a plain phone and see if you get dial tone IN THE SAME plug that the FAX is connected.
2helpful
Screen says no loop current when trying to send fax
It cannot not detect a dial-tone.
Test the line with a regular phone.
Unable to work phone no loop current what does this mean
Your fax machine cannot find a dial tone. make sure the ANALOG phone cord is plugged into the LINE port.
No loop connection?????
Use a regular telephone do you get a dial tone?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
I've got a Philips Faxjet 375 which displays NO LOOP CURRENT when I try to fax anything Any advice?
No dial-tone detected. Plug a regular phone into the wall jack and verify dial-tone.
Make sure you are plugged into the LINE port of the fax machine.
5helpful
3answers
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Aron
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
