see this causes: It spins, but doesn't pump drain line is clogged, remove some sock with pliers+test the pump for defective propeller, and replace DO NOT REPAIR It doesn't spin or pump frozen pump puller +and replace the pump It pumps, but the water returns if the drain hose reach more about 4 inches, cut of the excess if the hose is lower, install air/gap siphon break assembly see the diagram. God bless you
gringing noise is never a good sign check the main bearing these are notorious for having bearings go and if it is bearing find a new machine its not worth fixing it is costs more then the machine is worth to replace
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
