To switch between Daylight Saving Time - on or off:
1) Turn on unit - Press the picture of the wrench and screwdriver at the bottom.
2) At the next page, select "System"
3) At the next page, select "Time Zone"
4) Select "Daylight Savings Time" at the bottom to toggle it on or off
It is because the daylight savings time is enabled. you need to disable it and the time will be current to your correct time zone.
You need to resynchronize your GPS unit with 'active satellites':
The easiest way, would be to force your GPS to resynch by setting User/System Options -> Time zone to another adjoining time zone and set set it back to your country/state time zone.
Hope it helps: let me know how you go.
Check your time zone!
