Measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
1)check the contactor/relay of heating element is working?(check the supply at the heater coming)
if it works
then u must change the heater.
Hi, I have the same problem with mine.
There are no burn marks on the PCB board so next stop is the heater.
How do I actually check if the 'contactor/relay of heating element is working?'
