Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How to change the ink of an epson stylus sx215
    President:
Press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Posted on Jul 19, 2010
  • 6 more comments
  • aglen39 Jan 19, 2011
    very helpful thanks
  • bobo la com Feb 07, 2011
    it says unavalible
  • rvculley Mar 29, 2011
    Wonderful! Could get no help from Epson or ink supplier when printer arrived with cartridges not included.
  • fazer69 Apr 01, 2011
    Worked a treat thanks
  • nicklin1 May 06, 2011
    Si did mine, so what should I do?
  • pedro-195436 Jul 17, 2011
    thant you it was very help full. your peter
  • Sara Langley Jul 11, 2012
    Thank you. Very helpful.. Wednesday started well..
  • Lillian Cameron Nov 26, 2012
    Thank you, been trying to do this for ages!
    New Friend:
How to change the ink cartridge on a epson stylus sx210
Posted on Jul 27, 2010
    New Friend:
How do i change the ink cartridge on my epsom sx215
Please
Posted on Jun 15, 2010
  • mareemc Apr 28, 2011
    perfect - thank you!!!
    New Friend:
The Epson SX215 that I have will not allow me to use "Cheetah" compatible ink cartridges that do work on another Epson. Please, would anyone let me know how I can use such compatible cartridges.
Posted on Aug 08, 2010
  • 1 more comment
  • shalom93 Nov 13, 2010
    google 365 ink... my last purchase was 12 cartridges for £17...great stuff and next day delivery.
  • fivish Jan 09, 2011
    Asda do the ink for about £4.
  • owen_peter3 Jan 19, 2011
    I am most grateful! Thank you very much!
    Habit-Forming:
    New Friend:
  • 23 Answers
Here are few simple steps that you can follow if you want to change the ink cartridge in Epson Stylus sx215.
Step 1: Remove the lid of the machine that is located just below the scanner cover. If the carriage doesn't move when you open the lid then close the lid again and press the SCAN button along with the button above it together for a second.
Step 2: After pressing them, the display will show Ink Cartridge Replace. Press the Start button. Open the lid, the carriage will move to the far right section.
Step 3: Lift up on the flat plastic piece at the top, showing the inner compartment. You may then remove the cartridges that needs to be replaced, and insert a new one (be sure to remove all tape/packing materials first).
Step 4: Then close the lids, and the printer should recognize the new ink.
Note you may have to press start again after this process, and the printer may go through several minutes of running internal tests on the new ink before allowing you to resume normal operations.
Contact Epson Printer Support Number if you are still unable to resolve the problem by yourself.
Posted on Oct 03, 2017
SOURCE:
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
  • 187 Answers
SOURCE: How to Change ink cartridge
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Posted on Sep 30, 2010
SOURCE: changing ink in a epson stylus 8400
on the printer push setup, then push ink levels from there you should be able to select the change cartridge and be good to go
WW
Posted on Aug 13, 2008
hmerchant110
  • 7191 Answers
SOURCE: i have epson stylus sx215
You can download the installation driver and software from manufacturer's site by clicking this link
  • On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and download the drivers and software from the ist which opens.
Hope this solves your problem. Thanks for using FixYa.
Posted on Oct 04, 2010
SOURCE: Epson Stylus SX215 the ink cartridge holder won't
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Posted on Feb 22, 2011
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
How do I change the ink cartridges on an EPSON STYLUS Sx215
Hi joanmcd2, Just go to control panel and go to (printers for xp)/(device and printers win 7) open the properties of the driver and goto Maintenance tab and then click the EPSON Status Monitor button, you will see the ink levels and there will be an option to replace the ink.
for details pls dwonload the Sx215 manual on this link
Aug 05, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer (epson stylus sx215) wont recognize generic ink cartridge
- try to repeat a remove and replace all cartridge. with the careful and pass.
- if it does not changed, try to reinstall driver,s
good luck .......
Jun 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i change the ink in my epson stylus sx215?
  • Select "menu" and "setup mode"
  • Select "maintenance" and "change ink cartridge"
GOOD DAY
BOBUS
Feb 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have bought epson sx200 ink instead of sx215 will this still work as if not i will have to return it unopened???
Just have a look at the generic cross reference chart for aftermarket ink jet cartridges & you will see the one cartridge suits ten different Epson models
BLACK >>> T0891 Compatible; Ink contents 19ml
Stylus S20, S21, SX100, SX105johncsuk123
Stylus SX200, SX205, SX215
Stylus SX400, SX405, SX415
Jan 07, 2011 | Epson Office Equipment & Supplies
Epson Stylus SX215 the ink cartridge holder won't move into position so I can change a cartridge
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i change the ink on a espon stylus sx215 please someone help
Hi There This works on an Epson SX200 so maybe worth a try:
Start-control panel-printers-right click on Epson-printing preferences-maintenance-ink replacement
Hope this works
Barbara A.
Jun 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have a new epson SX215 and have lost the manual.I cant figure out how to replace the ink!! Help needed quickly please., Anne Cunningham
Hi Switch on the printer give a print job and open the panel the head comes to the centre and then you can remove.
Jan 29, 2010 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
33,935 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
