Should not be a problem. If you download the quick start guide from this site and follow the pairing instructions for your Bluetooth phone that should work well. http://www.jbl.com/images/media/J46BT_QSG_EN.pdf
Most bluetooth headsets or earpieces need to be "paired" to the phone before the can be used this usually just means you need to put both devices into pairing mode search (scan) from the phone select your earpiece in the list and enter a security code to complete the initial connection (pair) after that the earpiece can just be turned on and off with normal use
make sure both devices are in pairing mode. press and hold the button on the bluetooth until the light flashes blue and red. then with you phone in pairing mode it should see the earpeice. but the bottom line is that both devices must be in pairing mode. there will be a default code for pairing and it is probably 0000 or 1234
ok it took me a while the way u need to do this pairing is easy they just explain it really bad.
in your phone find the add device
press the call button till the purple light comes on
open the FLIP(microphone part AND THE EAR PEICE!!! people for get the ear peice)
press ok and have your phone start searching
once it finds the device press 0000 for the pin
your all set i almost sure this will work!!!
