Question about Bose on-ear TriPort Headphones
They dont open up well, the pads dont trun well
They dont open up wel, sometimes you have to pull hard to open them up, and the pads do not turn well either, i have to turn hards to turn the pads and they dont close easy either
  • Bose Master
  • 5,686 Answers
Try a bit of silcone grease in where it slides. You can get it from Maplin (UK) or Radioshack USA or that type of shop.
Posted on Jan 08, 2010
SOURCE:
Abs light, traction fault light on, radio does not operate
THE 1ST THING TO CHECK I BOTH SPEED CONTROL SENSORS LOCATED ON THE BACK SIDE OF YOUR WHEEL HUB...SOMETIMES THEY CAN BE CLEANED..TRUN WHEEL HARD RIGHT FOR RIGHT CABLE HARD LEFT FOR LEFT CABLE...PULL PIN OUT THEN CABLE VERY EASY TO REPLACE
Apr 12, 2014 | 2000 Jaguar S-Type
Power steering is hard to turn at times, fluid is full, is there a belt other then the serpintine??? i dont see one on the power steering pump
does it make noise when turning ? when installing new power steering pump with both front tires in air on jack stands or jacks start and fully steer right fully steer left repeat a couple times and shut off now pump is bled place on ground and test....by turning take a drive....
Mar 19, 2011 | 2002 Dodge Stratus
When i trun the streeing seems to get hard to trun and sometimes then lock up for a sec...
check power steering operation at 3000 rpm, if it working properly, you need to replace yoru power steering pump. it is a very common problem on that year f150
Sep 06, 2010 | 2004 Ford F150
My turn signals don't come on and it is not the bulb you, they come on at all different times
Sounds like you are describing that they work sometimes and then they dont? Very normall condition. Your trun signal relay is bad. Right side of your steering column look up to the right. Ford hides them in a small plastic box about half the size of a cigarrette box. pull of the cover and you should find a blur relay. Replace it. They are trickey to find and you can overloook it. Above the trans hump up in the dash, sometimes the are on the frame work of the dash.
Jan 26, 2010 | 1999 Ford Explorer
My cymbals wont work for my drums
wel if the symbols dont work thats becouse the censor inside the pad is broken the only way to fix it is to open the pad and saulder the wire bak into place
May 27, 2009 | Activision Guitar Hero World Tour Guitar...
I cant get my bluetooth to connect to my ps3
reset it and trun it off and trun it back on at the sometime
Feb 16, 2009 | Sony Playstation 3 (PS3) Console
Volvo 1990 Model 740 Trunk Lock key was broken in it
if it can be opened from the outside i guess yo dont need t lock it in the first place right?!! wel that's a joke ok
now if you can drop the back rest of the rea seat you ca crawl into the trunk and pull the lever to relese the trunk open hopefully there is not much of stuff inside our trunk!!!!
Nov 14, 2008 | 1990 Volvo 740
Can't find the choke for cold starting
well its the handle on the left side you should just pull on it.
Oct 21, 2008 | 1993 Volkswagen Golf
BRAKE LIGHT
This light should turn off if you replace the pads with pads that have the indicator wire on them. The light truns on when you wear the pads down to the wires and the wires break and cause an open circuit that turns on the light. If your new pads have the wires and are installed correctly, the light should turn off by itself.
Sep 30, 2008 | 2003 Audi A6
Changing brake pads on 1996 honda accord
brake pads are one of those things that just dont last forever, using excess braking will wear them faster, not a hard or expensive fix to do yourself, just tell an auto parts store year make and model, they will give you the right pads, jack it up remove the wheels, take the old ones out and put the new ones in exactly how the old ones were, sometimes you need to turn rotors, and usually pads come with this gel to put on the pads. maybe 2 hours for the inexperience mechanic.
Jul 24, 2008 | 1999 Honda Accord
Bose on-ear TriPort  Headphones Logo
157 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
