Presto 04821 Orville Redenbacher's Popcorn Maker Logo
Posted on Jan 07, 2010
I have lost the directions for use of power pop popcorn popper with power cup concentrators
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Jan 07, 2010
Anonymous
Contributor
Level 1:
Answers
49
Questions
0
Helped
27396
Points
80
You are looking for instructions for the 04830 Microwave corn popper. They can be printed at the Presto web site www.gopresto.com look for instruction manuals on the home page.
1helpful
Can't find directions. How much popcorn do I put in, and how much time do I set on my microwave?
1/3 cup popcorn, 1-2 Tbs. oil (optional). The time depends on how powerful your microwave oven is and whether you are using a Power Concentrator, but it will be between 2 and 5 minutes (closer to 2 minutes for a 1200 Watt oven; closer to 5 minutes for a 650 Watt oven)).
You can find the instruction manual on the Presto website.
https://www.gopresto.com/downloads/instructions/04830.pdf
Popcorn popper 50030178 I found this old popper like my nanny used to use. But I don't know how much popcorn or oil to use can you help me. I have the measuring cup lid all the parts with it.
What type of popper is it? The 50030178 model isn't one I'm familiar with.
For most of the small air poppers, such as the Presto Air poppers, fill the measuring cup lid with popcorn so that the popcorn is level with the top of the cup. Add this amount of popcorn to the popper. On those units, there is a fill line inside the popping chamber. Do not fill past the line. For these air poppers, if you want to have butter or margarine on the popcorn, add 3 tablespoons of the extra to the lid after you replace it on the popper.
For the Hamilton Beach Hot Oil Poppers, the manual for the 73300 is available here: http://www.hamiltonbeach.com/use-and-care/use-and-care.php . Fill in the type of device and then the model. The amount of oil and popcorn will depend on how much you want to make. For a single serving, you need 2 T (tablespoons) of kernels and 1 - 1 1/2 t (teaspoon) of oil. For enough popcorn for a family, you should use 1/2 cup of kernels and 1T of oil. http://useandcares.hamiltonbeach.com/files/840190701.pdf has a full chart of the amounts on page 6.
I hope this helps. Please add a comment with the brand of popper and I'll check for a specific chart for that unit.
(It's been a while since I used the air popper that I used to have.)
I purchased a nordic microwave popcorn maker and misplaced the directions for making the popcorn. I need to know how much popcorn to put in the bowl and amount of oil if any is to be used. I would...
The Nordicware Popcorn Popper is one that actually works in the microwave. The 3-Qt. Popper makes light and fluffy popcorn in about 4 minutes. Just place 1/2-cup of popcorn kernels in the bottom bowl and cover with the lid. No oil needed, makes up to 12 cups of popped corn. Good luck Richard
Nov 14, 2010 • Vacuums
I have two of your popcorn makers and lost instructions on the amounts of ingrediients. I need to know how much corn, oil and salt to put in aluminum popper thank yhou
The manual says to put 1 to 3 tablespoons of oil in the popper, and when hot, add 1/2 cup popcorn. Salt it after dumping the popped corn into a bowl.
47helpful
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
No instructions but wanting to know where do you put in the butter for the back to basic stove top popper
The manual says, place butter in cup, hook cup onto the rim of the pan below the "butter cup"marking on the lid, and the butter will melt and drip evenly onto the popcorn as it pops. I haven't tried it; hope it works for you.
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
3helpful
I have a Retro Series Popcorn maker, new. Can you tell me the kettle size in OZ, 2,3,4 etc. I have pre-measured packets given to me that are for a 4 oz Kettle. Thanks Dan Martin
Hello Dan, According to the manufacturer specifications, your popcorn popper has a 2 ounce capacity kettle. so you should be able to take those premeasured packets and by using exactly (close enough) half, get the desired results of pop corn out of your popper.
If you also want to use your own popcorn, here's some directions that will let you do that also.
First, turn on the popper and add 1 teaspoon of oil or butter, you can also use Land O' Lakes Margarine as it doesn't burn the popcorn like most butter will do so this is a personal preference (so you can use whatever your preference is but it must be melted). I've not tried it un-melted but I don't think it would work too well.
Then add ¼ cup of unpopped popcorn, brand doesn't matter. Wait and within 5 to 10 minutes it will hve popped.
Hope you find this Very Helpful and best regards!
17helpful
3answers
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Top Presto Kitchen Appliances - Others Experts
Paul Bade
john h
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
