Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I must update my windows xp and i don;t have a cd-key
Anonymous
Level 3:
Guru:
  • Master 458 Answers
  • Posted on Jan 07, 2010
Anonymous
Master
Level 3:
Guru:
Answers
458
Questions
Helped
101767
Points
1087
You can update your Windows XP service pack 2 by installing service pack 3.
This will upgrade your Windows XP and it will make it perform much better.
Download an official copy of Service pack 3 from Microsoft downloads center, through the link bellow.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
2answers
Slipstream post XP sp3 updates
The same way you slip streamed SP3. You can download all the updates here. http://catalog.update.microsoft.com Alternately you update your system to a base install get all the updates and create a ghost image.
tip
How to repair windows xp operating system
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
When presented with the screen below. press the F8 key to continue.
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different.
Note: If you need assistance with a repair installation, please start a new topic in our Windows XP Forum. This topic is also open for comments, but not all will receive a reply.
IMPORTANT NOTE: After running a repair, you may find that Windows Update refuses to install the most recent 80 patches. This is because the latest version of Windows Update is broken, and doesn't register some DLLs if they're previously been registered (as happens with a repair install). Here's a work around until they get it fixed:
Stop the Automatic Updates service. To do this, follow these steps:
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
exit
Register the file that is used by Windows Update and Microsoft Update. To do this, follow these steps:
At the command prompt, type the following command, press ENTER after the command, and then click OK when you receive a verification message:
regsvr32 %windir%\system32\wups2.dll
Note: for x64 machines regsvr32 %windir%\syswow64\wups2.dll
Start the Automatic Updates service. To do this, follow these steps:
net start wuauserv
exit
on Jul 02, 2010 • Computers & Internet
tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
Let's get started!
Let's get started!
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 • Computers & Internet
2helpful
2answers
My windows xp every days comment me u must active ur window 25 digit product key ( left two days )
Your Windows XP is not activated. This means you must find your original Windows XP disc, and the sleeve that the disc comes in should have the product key on the back.
Type in this product key to activate Windows.
Thanks for using FixYa.
Window xp service pack2 keys
Hi Dear!
Well we fixya don't allow us to provide any keys or serials.
You should get your key from the microsoft or if you bought a cd from a local store check out the packing it might be written somewhere on the CD Casing.
Gimme a mail for further assisstance
Thanks
tip
13 Steps to Change or Recover Windows Administrator login Password in...
Have you lost your Windows XP administrator login password, and you don’t know what to do? Here are thirteen simple steps that you can use to change or recover administrator login password of your Windows XP computer.
  1. Insert the Windows XP CD in your CD / DVD drive and restart your computer with him. To do this, after ensuring that established the system BIOS to boot from the CD as first choice. Check your system BIOS to see what is more.
  2. a “Press any key to boot from CD or DVD” message is displayed, press a key to boot from the Windows XP disk.
  3. Windows Setup will now inspect your system and load the required files.
  4. On the “Welcome to Setup” screen, press Enter to start Windows Setup.
  5. Scroll down the Licensing Agreement screen and then press F8 to accept it and proceed further.
  6. On the Setup screen that is displayed next, you may get an option to repair Windows. Select the Windows XP installation you want to repair and then press R to start the Windows repair process.
  7. During the repair process, Setup will first check the disks on your computer and then start copying the required files. This task will take a few minutes.
  8. After the files are copied, you will be asked to restart the PC. If you don’t, PC will restart automatically after 15 seconds.
  9. When the PC restarts, don’t choose to boot from CD. Setup will automatically resume and you will see a message box informing you that the Windows installation is on.
  10. During this process, you need to keep an eye on the left had panel of the screen that informs you about the setup status. When you see that the “Installing Devices” task is in progress, press the Shift + F10 key. This will open a Command Prompt window that you can use to perform several admin tasks on your computer. Surprised! Well, yes the world’s most popular operating system does have a few security loopholes.
  11. At the command prompt, type NUSRMGR.CPL and then press Enter. The User Accounts control panel window will display.
  12. In the User Accounts window, you can perform various user management tasks, such as, reset passwords, change password, create new user, and configure no password login. After making the required changes, close the dialog box, exit the Command Prompt window and then proceed with the repair process. You may need the Windows XP product key, so keep it handy.
  13. After the repair process is complete, you will be able to log on to your Windows XP computer using the new password you set during the repair process. In case, you choose not use a password, you will not be asked for one.
This process will not have any affect your existing programs and personalized user settings. However, if you find this method to change or reset administrator password in Windows XP complicated, you may opt to use a reliable third-party tool, such as Windows Password Recovery Tool .
This is a real handy tool that enables users to perform several Windows recovery tasks, such as recover passwords, make and restore data backup, manage partitions and recover lost data.
aiosp_title=13 Steps to Change or Recover Administrator login Password in Windows XP
aiosp_keywords=windows xp password, xp password, xp administrator password,windows xp administrator password,xp login password,windows xp login password,recover xp password, change xp password, reset xp password, bypass xp password, crack xp password
aiosp_description=Have you lost your Windows XP administrator login password, and you don?t know what to do? Here are thirteen simple steps that you can use to change or recover administrator login password of your Windows XP computer.
aiospwlwbsend-->
on Apr 01, 2010 • Computers & Internet
I am trying to restore Windows XP Professional to my laptop. Can you help? I have the original product key and proof of license number
  • Turn your computer on and insert your Windows XP professional CD in the CD/DVD reader. Monitor the screen and press the key necessary to enter the "Boot Menu," usually F8 or F12. In the "Boot Menu", select your CD/DVD drive and press "Enter."
  • 2
    Press any key to boot from the CD when prompted to do so. From the "Welcome to Setup" screen, press "Enter". Accept the license agreement by pressing "F8."
  • 3
    Select the Windows installation you want to restore and press "R." You will usually only have operating system to choose from. The system repair install will proceed automatically.
  • 4
    Click the "Start" menu after the installation process is done. Click "Run" and type "sysdm.cpl" before pressing "Enter."
  • 5
    Select the "Automatic Updates" tab and click "Automatically download recommended updates for my computer and install them." Your computer will install the updates that were lost when you repaired your Windows XP Professional operating system.
  • 1helpful
    14helpful
    2answers
    XP service pack 2 Genuine problem
    How to make your Windows XP Service Pack - 2 Genuine Hi all my users, I m back with lots of thing.
    Lots of my students & Users ask me How to make Windows XP Service Pack - 2 Genuine, beacuse of security features, microsoft update, downloading software & installing some software like Windows Media Player 11 & Internet Explorer 7 and Many more facility.
    Here some simple steps to make your Windows XP Service Pack - 2 Genuine----
    1) start > run > “regedit” (without the quotes of course)
    2) go to the key:
    HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\Windows NT\CurrentVersion\WPAEvents\OOBETimer
    …and doubleclick on it. Then change some of the value data to ANYTHING ELSE…delete some, add some letters, I don’t care…just change it!
    now close out regedit.
    3) go to start > run > “%systemroot%\system32\oobe\msoobe.exe /a” (again, dont type the quotes)
    4) the activation screen will come up, click on register over telephone, then click on CHANGE PRODUCT KEY, enter in this key: JG28K-H9Q7X-BH6W4-3PDCQ-6XBFJ.
    Now you can dl all the updates without activating, and the Genuine Microsoft Validation thingy won’t bug you no more!!
    Formatting a laptop's c: drive
    That all depends on how much preparation you do before hand and how much experience you have installing operating systems and resolving issues that come up. Things to look out for: -Have all the hardware drivers on a readable CD. The manufacturers original CD is best. -Do a test boot to the install CD just to make sure it works. -Make sure you have a legitimate Windows software key. There should be a Microsoft sticker with the key printed on it. -Keys can only be used to install the operating system three times. If you purchased this new you should be OK, if its used the previous owner may have already reformatted a couple of times so be prepared to spend time on the phone with Microsoft. -Do this somewhere where you have access to a broad band connection so you can download the updates and patches. -Remember to pull your data, shortcuts and passwords off the hard drive before you format. -Make sure you document the software you have currently installed. Make sure you have the installation CD and the license key to reinstall them. -Some manufacturers like to create a special partition for diagnostic utilities. Make sure you don?t delete that unless you know what you?re doing. -Allow for plenty of time, it takes about an hour and a half to two hours for a pro to save data, format, reinstall and update software. If this is your first time it may take you a evening if nothing goes wrong. Bottom line is you don?t want to be doing this if you have any major projects, taxes or anything else coming up soon. Good luck.
    Top Microsoft Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
