HP DeskJet F380 All-In-One Printer Logo
George Papaevangelou Posted on Dec 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It works very well as printer or photocopying but not as scanner
It works very well as a printer or o photocopying machine, but not at all as a scanner. It gives message "Unexpected internal error occured". And it tells me to restart the programm, reboot the pc or reinstall photo and imaging software.
It started after a unistallation and reinstallation of the programms.
honey
Level 3:
Master:
  • HP Master 262 Answers
  • Posted on Jan 30, 2018
honey
HP Master
Level 3:
Master:
Answers
262
Questions
Helped
320353
Points
1535
Might be scanner drivers corrupted, Reinstall the Scanner drivers again. Most probably this will work greatly You can try this no (877-690-9305) for the solution. Support For Hp Printer
4 Related Answers
Anonymous
  • 16 Answers
  • Posted on Nov 28, 2007
SOURCE: scanning software does not work at all
dear ,
there is a cd comes bundeled with the printer caled "drivers and software cd" if u have it insert it and follow on screen tips. if u dont have it contact me ill redirect u to my ftp to download the drivers and software
Anonymous
  • 2785 Answers
  • Posted on May 16, 2008
SOURCE: An unexpected internal error has
scan your pc for viruses by disabling the system restore then reinstall the driver for the scanner
Anonymous
  • 15 Answers
  • Posted on Aug 15, 2009
SOURCE: Error! An unexpected
Please clarify what program you are using when this error message accures. It seems like it's possably just a software problem, so what I would recommend is to check your event log to see what errors it is logging. The answer to your problem may reside in there.
Anonymous
  • 63 Answers
  • Posted on Sep 05, 2009
SOURCE: can't scan image to word or photo gallery
First thing to do is try to check if your windows XP is a 32 or a 64-bit. You can do this by right clicking the mouse on My Computer icon and then left click on properties. Now try to load the right and updated driver. If it still won't work. Go to Control Panel>administrative tools>services>scroll down and look for WIA ( Windows Image Acquisition). when you double click on it you should see it it is running, stopped, make sure that it is started. If still won't work try using other application like paint.
How do l unlock scanner the printer is no longer photocopying
There is usually a manual sliding switch to rear of machine that is used to lock scanner head for transportation.see if it has been switched to the padlock symbol.
Gestetner Aficio MP 1600 was connected to my System and I use it as photocopier, scanner and printer. The machine's Drum was changed of recent and it has failed to scan any of my documents. However, I...
Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
If you still have any doubt reply to me.
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
2helpful
Can I photocopy without the computer as it is not working at the moment
You shoulde be able to insert your document into the scanner section face down, close the lid and just press mono start or color start and it photocopy for you. as most of the printers now a days dont need a computer to operate hence why some are called standalone machines.
1helpful
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
All in one printer, scanner and photocopier wont work?
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
I have a HP laserjet P2015 printer. Please could you tell me in what part of the paper container do I put envelopes, to have an address printed on them.
http://h71016.www7.hp.com/html/interactive/lj2015/model.html?jumpid=re_r2515_3d/ProdCat/IPG/VAcontent/BlackWhitePrinters/LaserJetP2015/3D|ProdPage|flash&clang=enna
plz paste the link into your browser and you will find the required information
2helpful
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
Hp 1317 psc
you didn't describe your problem briefly. 1. Check if you photocopy anything, it is coming out correctly you are doing. it means your scanner is perfectly allright. 2. if you are not able to photocopy with this printer, it means your scanner is not working properly. But if it photocopying properly and in windows it is not scanning it means software is not working properly, try to arrange new software from anywhere and try.
k24674
Grand Canyon Tech
Grand Canyon Tech
