Hi There
I have found this for to read and hope this will help you. Let me know how it goes.
The clock stopped
The
non-electronic clocks on electric range/ovens often don't last long.
That's a problem, because the clock is essential to the self-cleaning
and timed-bake features. Clocks are rarely repairable--you usually just
have to replace them.
Electronic
clocks have been more reliable. But, they're often integrated with
several other features of the range/oven. So when the clock develops a
defect, it often renders the entire oven and broiler inoperative. The
electronic clock is usually integrated with a circuit board, and the
touchpad that holds the buttons you press is often a separate
component. If your electronic clock is defective, you may need to
replace the touchpad, circuit board, or both. Although these may be
expensive, they aren't usually very complicated to replace.
Thank you for writing to fix ya.
Best Regards Richard
Testimonial: "Thankyou for your response I suspected that it will require a new clock which I have located online. many thanks"
