Meu Pen Driver é um kingston DTI/1GB, quando conecto no PC ele instala os drivers, aparece o ícone de disco removível na unidade (F), porém, quando tento abri-lo ou explorá-lo, diz: Insira um disco na unidade F:. Gostaria muito de saber o que devo fazer para ressuscitar o meu pen driver???
SOURCE: Driver for Pen drive Kingston 2 GB
Hi
u do ot require driver for xp. its plug and play
if its not working than something wrong with ur xp- usb configuration. pls checkp their
SOURCE: meu pc depois de formatado
click start control panel
administrive tools computer management device manager scroll down universal
serial bus controllers you should see a yellow question mark?
right click to reinstall
drivers
if you can see your usb
drive but its not working
ports(com&lpt)right
click update driver
click start click on my
computer you should see your drive
right click then select
format
another way is to control panel administrive tools computer management
disk management right click on your drive select format
hope this helps
SOURCE: conecto la unidad usb a
click start control panel administrive tools computer
management device manager scroll down universal serial bus controllers you
could see a yellow question mark? right click to reinstall drivers if you can see your usb drive but its not working ports(com&lpt)right click update driver if this fails to
fix the problem check the USB leads that attach to the motherboard usually
red white green black make sure they are securely seated and have no dust build
up on them dust will cause static and a lot of unforeseen problems for a
computer and its parts click start control panel administrive tools ,computer
management ,device manager look through all of your devices if you see a yellow
question mark?or exclamation mark ! or red x right click to reinstall drivers hope this helps
