I have HP LaserJet 1522 printer and I am getting an error message ''memory is low'' and an error code 49...I performed the steps mentioned in the service manual but the problems still persists.
Most likely the Orange Clip that surrounds the sensor contacts on the front edge of the cartridge was not removed. Open the machine, look at your cartridge, make certain that any clips or protectors are removed, clean the contacts if in doubt and reseat the cartridge... your problem should be solved.
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages?
Like scanner error 5?
If so call hp tech support 1800 334 5144.
Al
1. Turn the printer off 2. Hold down the down arrow and the cancel button 3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1. Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
