Problem recording off hd tv with cable box from toshiba vcr w522 at certian time? i can set the vcr clock and set up the vcr to record but only the timer goes off but the machine dose not record. i tried some settings but with out the manual or technical know how i'm at a lose.
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
