The drain and spin cycles on my Fisher and Paykel smartdrive excellence washing macine do not work. The wash cycle does work tho. Hope someone can help. Thanks, Jill
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
