Vegetables in fruit and vegetable bin are freezing. Also, water dispenser has stopped dispensing water. I suspect water is frozen.
Help!
Defrost the unit manually and turn down the thermostat and retry,if it still too cold try replacing the thermostat,or in some models the thermostat sensor
Call at Service Station!!
Yes may be change the filter. Fruits Vegetables
Change the filter.
I solved my problem by going someplace that wasn't going to charge me!
Cleaned under and back of fridge and took off plate in back. Replaced filter pad and water line. Has always made ice but water dispenser does not work. If I use a hair dyer on warm setting to blow air onto coil behind vegetable/fruit bins water will flow but stops within an hour. One time I could hear the water freezing and stopping. The hair dryer was a "solution" a repairman used to have water flow. Of course he was not there an hour later. Second repairman replaced a part (nothing stated on receipt) and fridge still freezes and dispenser does not flow. Could the damper not be closing properly? Saw posting on another website.
