There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
My oven door locked when I turned the oven to 350 degrees and would not unlock. I tried shutting the power off several times for 30 minutes and nothing worked. I finally took a small screwdriver and gently pryed at the door at the top left cornor and the door popped open. The lock mechanism was still hung up in lock position and finally I took a hammer and gently tapped on the lock at the center top of oven and it retracted and oven now works properly again.
