Computers & Internet Logo
Posted on Jan 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP G50 laptop,problem with apostrophe key
Using an HP G50 laptop and can't get the apostrophe key to stop printing an accented lower and upper case e. The question mark key is also producing an accented e, only the accent goes in the oppposite direction from the apostrophe key. What do I press to get the apostrophe and question marks back????
  • Brett Duxbury
    Brett Duxbury Jan 16, 2018
    Hi naapme, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    version of windows ?
alibaba69
Level 3:
Master:
  • Master 490 Answers
  • Posted on Jan 16, 2018
alibaba69
Master
Level 3:
Master:
Answers
490
Questions
Helped
186605
Points
1312
It seems likely that you touched the CTRL key while pressing the apostrophe key, which creates a shortcut to an accented letter eg CTRL+',e will give ?.
Try Ctrl + e again to see if it goes away..cheers
4 Related Answers
Anonymous
  • Posted on Dec 15, 2008
SOURCE: How can I unlock the blue function keys on my HP Pavilion dv2000?
Hi, I had the same problem and found the solution on another website:
To turn on and off Bilingual blue keys:
Hit Ctrl + Shift + shift
(yes, both shift keys at the same time in addition to ctrl)
and that turns on and off the Canadian bilingual blue keys on HP lap tops.
It's so annoying and happens to me frequently. Hope this helps.
M
joegoldman
Joe Goldman
  • 337 Answers
  • Posted on Oct 13, 2009
SOURCE: how to make french accents marks on a laptop that
You need to tell windows it has a french keyboard:
In the control panel, go to regional and language options.
Go to the keyboards and languages tab, click change keyboards. On the window that pops up, click on the general tab. You probably have just the us keyboard installed. Click add, then choose either english-canada or french-france, then click to add the french keyboard. Click preview to see where the accent keys will be (so you can find them). Now, select the french keyboard and click 'move up' so the french keyboard is above the us english one.
Voila!
Hope this helps. Post a comment if you get stuck.
Joe
Anonymous
  • Posted on Feb 01, 2010
SOURCE: Where is the apostrophe on my keyboard.
to the right of the line with kl;. to the left of the enter button
Anonymous
  • 689 Answers
  • Posted on Sep 10, 2010
SOURCE: acer aspire one keyboard.
you have chosen the wrong settings when you configured your keyboard .Choose correct keyboard layout from there-it should work alright
How can i turn off the green characters on my asus keyboard?
ust press the CTRL+SHIFT keys and you will switch from French to English
I’m happy to assist further over the phone at https://www.6ya.com/expert/sherri_bf92738d7f5863ad
The @ symbol won't work and will only print as a apostrophe
Try using the ALT Car key to the right of the space bar.
2answers
How can i type latter Apostrophe with dell laptop
Apostrophe key is next to the enter key
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My lower case e shows vertical lines, the upper case is fine as are all other keys
The lower case "e" spoke on the print wheel is either bent or broken. If it's bent you may be able to straighten it, if broken it needs replaced.
DickyO
Wireless capability shut off. what function key combo do I press to restore? It's a HP G50 Notebook
There is wireless switch - either under the screen or on the front of the computer. Find it and check position of the switch. Usually, there is light next to it. Good luck!
2answers
How to type caracter on top of letter n
Under Windows hold down ALT while typing the appropriate number code on your numeric keypad to create characters with tilde accent marks. For Windows, the number codes for the upper case letters are:
ã 0195
ñ 0209
õ 0213
For Windows, the number codes for the lower case letters are:
ã 0227
ñ 0241
õ 0245
When the caps on i get lower case print when caps off i get upper case print i cannot get numbers even when caps on or even if its off
in your case it seems that your shift key has stuck or not working properly check your shift key either right one or left one....do reply back
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
