E000
Fuser thermistor, heater thermal fuse
E001
Fuser thermistor, or triac
E002
Fuser thermistor, thermal fuse or triac
E003
Fuser thermistor, heater, thermal fuse or triac
E004
Triac or fuser won't shut off
E007
Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407
E010
Main motor drive problem
E030
Counter
E041
Paper deck motor, clutch or sensor
E064
Composite power supply or main motor board
E202
Scan problem. Motor sensor
E210
Lens drive problem
E220
Exposure lamp
E240
Main board or composite power supply
E260
Main board, power supply cooling fan or composite power supply
E261
Composite power supply or fluctuating power
E400
ADF communication to machine
E401
ADF pickup motor or sensor
E402
ADF belt motor drive
E403
ADF feed motor or slip sensor
E404
ADF exit motor
E411
ADF document detect, or registration sensor or edge sensor
E500
Sorter communication problem
E510
Sorter drive problem
E530
Stapler guide b
Error e000 - error with fixing unit. Try to disassemble printer, remove fixing unit. Check heater element's and thermal sensor's impedance. Check connectors.
That is a error code for the fixing unit... Did you try to unplug the copier for a few minutes? It may reset, if not you may have to have the fixing unit replaced...
1. Hit Additional Functions Key 2. Hit # key 3. Arrow to number 7, Printer and hit Set 4. Arrow to number 4, Printer Re-Set and hit Set. 5. Yes, re-set printer (hit minus key - back arrow). 6. Unplug the machine and plug it back in.
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
