Re: My reliance 606 water heater drain valve is...
You are going to have to drain it anyway. So drain it and take the old one with you to get a new one. In case you don't know turn the breaker off before you drain it. If you don.t you will melt the heating elements. They get too hot out of water.
thermostat.Check Settings,and if you turned it up or down while power was still on, thenchange them both. also t+p valve may be weak from temp overshoot.Change it if it continues after replacing thermostats
Reliance 606 240Volt water heater. This water heater is fully repairable by homeowner
You have some hot water so that says upper element is good. It also says electricity to water heater is good. Also your reset button is not tripped. water heater is not overheating. And covers and insulation are installed properly on water heater. Water pipes are not clogged, and tank is not leaking water on floor.
Add a comment for more free help. Also take advantage of fixya phone service. For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
Here is the link for the users manuals for the RELIANCE 606 30 GALLON GAS WATER HEATER, depending on the style you have - tall, short, etc. http://www.reliancewaterheaters.com/lit/om/g606.html
